when storing a bare block how do i prevent rust??
Old Sep 11, 2005 | 05:20 PM
eds96ragtop's Avatar
I have a bare lt1 block that has been sitting for a few months and will sit for a few more months b4 i get the money and time to rebuild it. I has a little bit of rust on the surface of the cylinder and crank witch i cleaned of with gentle rubbing and some very very fine steel wool. I was told to coat it in oil but that i would have to do every couple of days probably to keep rust away so i was thinking a light coat of paint may do.
anyone else have any ideas??
Thanks for the help.
Ed
Old Sep 11, 2005 | 05:32 PM
firetird's Avatar
Re: when storing a bare block how do i prevent rust??
just dip a rag in oil then wipe the block down and put it in a large plastic bag. it will last longer than a couple of months that way.
Old Sep 11, 2005 | 06:27 PM
Spray lithium grease will stick real well. Just clean it up with oil when you get ready to build.
Old Sep 11, 2005 | 09:57 PM
IRONFIST's Avatar
Yep, anything to seal the block and then a bag.
I've even used clear coat...
Old Sep 12, 2005 | 08:34 PM
JaysGone's Avatar
Fill a spray bottle with motor oil,clean or old doesnt matter. Douse the crap out of the thing. Then a big platic bag and twist tie it.Check it in a few months and resoak if needed.
Old Sep 12, 2005 | 11:37 PM
Thanks for all the advice guys I appreciate your help. Im gonna soak and wrap it asap.
Ed
Old Sep 13, 2005 | 01:23 PM
MarineReconZ28's Avatar
I wouldn't use WD-40 or anything like that.
Victor Lamb
Aug 26, 2017 02:52 PM
Sergio
Jan 27, 2016 04:27 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Sandersen511
Jan 13, 2015 03:49 PM
