what the??? tranny issues i guess?
Old Nov 27, 2004 | 12:40 AM
wblocker's Avatar
ok, i have 95 z. just had a mad z tune, was programmed for 3:42 gears, the strange part is the speedo is correct!! i cannot go past 60 in second gear or i will be bouncing off the rev limiter!! i thought i had 3:73 gears but i guess not! according to others it should be the same gearing in the tranny as the ls1, as i have 2 ls1's to compare to, both will do 75 in second, i cannot go past 60 in the lt1!!!!! what is going on here! could it be a transplanted tranny? im at a loss here!! please help me!!! what do i have here? not stock, i know that!, the speedo is confirmed as i have a really good friend that is a lake st. louis cop and he has shot me with radar and it is the same that i was reading on the speedo. did the 94-93 trannys have a different ratio? let me know!!!
Old Nov 27, 2004 | 11:17 AM
Need4Camaro's Avatar
Re: what the??? tranny issues i guess?
Here I was thinking I was hard on my lil 6'er... Why would you want to go past 60 in second?
Old Nov 27, 2004 | 11:33 AM
wblocker's Avatar
the m6 z28's are capable of 75 in second gear without hitting the revl imiter,, i was told that all m6/3:42 cars can do this, both ls1's i have can go 75 in second without even coming close the rev limiter, 5600-5700rpm or so, what is the deal with my 95?
Old Nov 30, 2004 | 10:43 AM
and here it is my rev limiter is at 4,000 RPMS...
Old Nov 30, 2004 | 12:30 PM
rngilliland's Avatar
You said you had a transplanted trans. If it is a 93 trans it has a 2.07 second gear ratio. The 94 and later trans has a 1.78 second gear. That would be about 61 mph for the 93 and 71 mph for the 94 trans at 5700 rpm with 3.42 gears.
BigWil
Mar 29, 2015 12:24 PM
jackpawt883
Feb 26, 2015 09:04 PM
Cartercarterr10
Advanced Tech
Jan 15, 2015 09:13 PM
Snoman73
Nov 17, 2014 07:22 PM
