What resistors work with Pellet Code 15 for the VATS (security light on)
Old Oct 20, 2006 | 01:08 PM
CrimsonNJ's Avatar
I went to the dealership and they read I have Pellet Code 15. I told the guy at radio shack I need a resistor for my car between 11328 and 12292ohms. He told me they dont sell them and I need to go to a more specialized store.
Anyone able to link me to what I would need and do i combine resistors to make what I need?
Old Oct 20, 2006 | 02:16 PM
BadgeZ28's Avatar
Re: What resistors work with Pellet Code 15 for the VATS (security light on)
If you have that wide of range just ask for a 12K ohm resistor. That would be 12,000 ohms. The way to measure the VAT's resistance for your specific car is to use a ohm, or multi meter set on ohms and put the red probe on one side of the key chip and the black lead on the other side of it.
Old Oct 20, 2006 | 03:29 PM
Shoebox could have saved you a trip to the dealer:
http://shbox.com/1/4th_gen_tech2.html#pass_key
Old Oct 21, 2006 | 02:19 AM
oneslowz28's Avatar
a 12k ohm resistor will work fine.
Old Oct 21, 2006 | 12:04 PM
CrimsonNJ's Avatar
1/4 watt or 1/2 watt
Old Oct 21, 2006 | 12:09 PM
CrimsonNJ's Avatar
My parts dealer was nice, he told me he'd copy part of the repair manual if i wanted to replaced the faulty part.
Old Oct 21, 2006 | 07:48 PM
oneslowz28's Avatar
I would use a 1/4 watt since its smaller. just besure to solder it and cover the whole thing in heat shrink.
Old Oct 22, 2006 | 10:44 AM
CrimsonNJ's Avatar
What is heat shrink and another person said use a telephone wire tap. If I put a 12k ohm resistor in would I just connect it with a telephone wire tap. one to each of the wires??
Old Oct 24, 2006 | 09:54 PM
CrimsonNJ's Avatar
Security light is off, thanks all.
I soldered a 10k, 1k, 470, and 330 1/4 watt resistor's together. Put telephone tap connectors on. Wrapped them 4 times in electrical tape and closed it up. Total cost $7.44.
It would have been 1.06 if my store had a 12k ohm resistor and if i didn't use the tap connectors, but it let me avoid having to solder inside my car.
Old Oct 24, 2006 | 10:04 PM
oneslowz28's Avatar
congrats but i would have soldered it and used heat shrink tubig to cover them up. the telephone tap thing is not something i would recomend.
Old Oct 25, 2006 | 01:25 PM
CrimsonNJ's Avatar
Why not telephone taps and why is heat shrink tubing needed?
Old Oct 25, 2006 | 03:34 PM
What is the thing you refer to as a "telephone tap"? I need a pic.
Old Oct 25, 2006 | 04:15 PM
nervekiler's Avatar
how did you connect the resistors to the car? did you wire them into the two white wires found inside the orange loom coming off the back of the key cylinder?
they are saying solder and use shrink wrap because its a more secure connection and the shrink wrap will help insulate the resistors against metal parts under teh dash which can screw up a lot of things in the car.
i install remote start systems and in tehse cars we have to bypass the VATS i use resistors solder them in and then use electrical tape to insulate.
at my best buy we have packages of resistors on hand i would have just gave you a bag full for you to disect and use whatver you can.. DEI gives me resistors with every alarm i install and i never use them just throw the bag in my toolbox.\
glad to hear you got it fixed though
Old Oct 25, 2006 | 05:49 PM
CDCamaro9534's Avatar
I did it the same way you did. It worked for a while, then I started getting the security light every now and then. And waiting for it to clear so I could crank the car. I put up with this for about 6 months, then one day when I went to leave work, it wouldnt clear for nothing. I spent 45 min trying to get it to crank over. Luckly I had tools at work to tear apart the bottom of my dash to get in and redo the work. After I got home, it got solder and heat shrink, and no problems since
Basicly do it right the first time, or you will get caught with ur pants down. Been there, done that
Old Oct 26, 2006 | 01:59 PM
Bud M's Avatar
me too
