What exactly is TB bypass?
Old Nov 5, 2004 | 03:06 AM
twiztedone01's Avatar
Ive seen in a lot of peoples sigs TB bypass listed as a mod... i know it has something to do with the throttle body but what exactly is it and what are the power gains associated with it?
Old Nov 5, 2004 | 03:13 AM
TobyZ28's Avatar
Re: What exactly is TB bypass?
Lots of info on past posts about this.
Basically the throttle body has coolant running into it via one pipe and out through another. TB bypass basically means you bypass the throttle body and connect the two lines right into each other (TB gets no coolant then).
The supposed purpose was to prevent your throttle body from icing over in very very cold weather.
Old Nov 5, 2004 | 05:36 AM
Kataklysm's Avatar
I thought it was supposed to keep the TB from getting hot since the hot coolant is going through it? When you bypass it, it's allowing the hot coolant around it so it doesn't heat the TB and cause the incoming air to be hot which would be more dense. The morsepower gains are minimal, it frees up a a few though.
Old Nov 5, 2004 | 07:36 AM
95GRNZ's Avatar
Thumbs up Re: What exactly is TB bypass?
http://www.geocities.com/MotorCity/6647/ta93/tbody.htm
http://www.installuniversity.com/ins.../tb_bypass.htm
First one is for LT1 and the second one is for LS1. Basic idea is the same.
Hp gains are minimal, if any, but usually it won't hurt, either. Unless you live in very cold climate. But even then you might not have any problems at all.
TS
Old Nov 5, 2004 | 10:24 AM
bond449798's Avatar
http://cgi.ebay.com/ebaymotors/ws/eB...category=33558
Old Nov 5, 2004 | 10:41 AM
ChrisS95TA's Avatar
On a 95 no kit should be needed, just run the hose from the drivers side to the passenger side metal tube on the valve cover and used to go to the passenger side of the TB. The clamps on the hoses are hard to get to, I have to wait to do my bypass until I take off the TB because it was pissing me off. Good luck
Old Nov 5, 2004 | 10:51 AM
bond449798's Avatar
Oh i did on my 2001 it was easy i bought a kit just like that one.
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
colts0455
Sep 2, 2015 12:41 PM
