what could happen if?
Old Sep 4, 2007 | 10:01 PM
stephenspann27's Avatar
I've had some problems with my A/C lately.. anyways.. I have all of the replacement parts in place and the system evacuated and charged. The only way I can get the compressor to run is if I jump the connections where the relay plugs in on the fuse box. And.. from what I read this is usually caused when the PCM detects too low of pressure and it disables the compressor from running. I read to "reset the PCM" which I assumed just meant disconnecting and reconnecting the battery? My dad has a scanner.. and I could use it to clear the codes... not sure if this is what is necessary.. My next question is.. if I run it like it is, with a wire jumping the connect, could it hurt if by the compressor running all the time?
Old Sep 4, 2007 | 10:16 PM
If the system is properly charged the pressure sensor should indicate ok pressure to the PCM. Reset the PCM by pulling the PCM BAT fuse for about 30 seconds. Hopefully, the compressor will now come on with the controls.
Old Sep 4, 2007 | 11:21 PM
where is the PCM battery fuse?
Old Sep 4, 2007 | 11:22 PM
ah.. the cabin fuse panel.. thanks I'll go give it a try
Old Sep 4, 2007 | 11:33 PM
that fixed it, thanks
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
