What is this?
Old Jul 9, 2012 | 03:38 PM
DomsZ28's Avatar
What is this?
I found this laying in my engine and not sure what it is. it has suction and I believe it leads to the PCV pipe...I cannot find where it goes however. My car has an abnormally low idle so hoping this has something to do with it? If someone could tell me where this goes I'd appreciate it. Thanks
Old Jul 9, 2012 | 04:21 PM
mrmint69's Avatar
Re: What is this?
It kinda looks like the fresh air check valve for the opti. I have an MSD opti so I am really only guessing, since mine doesn't look exactly like it.
Old Jul 9, 2012 | 04:33 PM
Re: What is this?
Shoebox has the info - filter/flow reducer for the Opti vacuum harness:
http://shbox.com/1/opti_vacuum_hose.jpg
Old Jul 9, 2012 | 05:03 PM
dave96ss's Avatar
Re: What is this?
What its missing is 1/4 inch rubber line, and the tiny 1/4 plastic elbow that plugs into the top air intake elbow, if you see A little hole in that elbow, then that is it, or at least that is how mine is set up, hope this helps.
Old Jul 9, 2012 | 05:38 PM
DomsZ28's Avatar
Re: What is this?
Hmm it does seem I am missing a part of it. Anyone know where I could order this? Looks like Im missing half the line.
Old Jul 9, 2012 | 05:40 PM
DomsZ28's Avatar
Re: What is this?
Just out of curiosity would this cause any idle problems or hard starting? it seems so small I dont think so..
Old Jul 9, 2012 | 08:04 PM
mrmint69's Avatar
Re: What is this?
You can get the hose at most auto parts stores by the inch. You might be able to rig it up to work with a little playing around.
Old Jul 9, 2012 | 10:57 PM
Re: What is this?
There are 2 vent lines. The filter/flow limiter is in the vacuum line that runs from the nipple on the bottom of the Opti cap to the vacuum on the driver's side of the intake manifold. That's where the part he is asking about is located, and Shoebox's photo shows the complete line. There is a line that extends from the filter/flow limiter to the Opti, that is not in Shoebox's photo.
The air supply line runs from the air intake elbow, where it plugs in with the blue plastic elbow, to the nipple on the bottom (rear section) of the Opti. There are no fittings other than the blue elbow in that line.
http://shbox.com/1/opti_vacuum_harness.jpg
http://shbox.com/ci/opti_vent.jpg
Old Jul 12, 2012 | 03:29 AM
SharleneH's Avatar
Re: What is this?
Fred, thank you for your links! Very useful for a newbie like me!
[EDIT] SPAM signature deleted
Old Jul 12, 2012 | 05:10 AM
Re: What is this?
And thank you for posting your SPAM from one of the most active spam IP addresses in Germany (84.16.224.15).
BANNED.
Old Jul 12, 2012 | 06:55 PM
ACE1252's Avatar
Re: What is this?
BANNED.
LoL!!!
