What The!!!!
Old Nov 4, 2005 | 04:05 AM
Future_Z_Owner's Avatar
What The!!!!
OK IVE ABOUT HAD IT!!!! I CANNOT REMOVE THE [ EDIT ] ELECTRIC CONTROLS OFF OF THE PASSENGER DOOR. IVE TRYED EVREYTHING EVEN FORCING IT OFF TO AN EXTENT. WHAT [ EDIT ] IS THE DEAL HERE! THE DRIVER DOOR WASNT NEAR AS HARD! IVE EVEN USED 2 PRY TOOLS! THIS THING WILL NOT COME OFF!
Old Nov 4, 2005 | 04:41 AM
Kris93/95Z28's Avatar
Re: What The #$^#$^@#@!!!!
If you're talking about the Window, Lock, mirror switch panel: you have tried to push in the clip on the leftt hand side so it will release, then the one on the right? You have to push those clips in because it won't just come out with you prying.
Old Nov 4, 2005 | 05:12 AM
Yep. I cant get to them.
Old Nov 4, 2005 | 06:46 AM
#1... Do not override or even test the language filter..... it is actually possible to communicate without using the F-word.
#2... Post in the correct forum. A problem with body parts does not belong on "LT1/LT4 Engine Tech". Moving to "General F-Body Tech & Info.
