weight difference between roll bar materials?
im looking to do weld in a 6 point wolfe bar and was wondering:
the difference between mild steel and chromoly is over 100 dollars, why is one so much more expensive then the other? i know chromoly is alot lighter, in a cage like this anyone have a rough idea of how many pounds lighter? and is there any other benefits to having chromoly? thanks for any help
How much weight you save depends on what you are building. An NHRA "roll bar" (11.50 - 10.00) is mostly 1.75" tubing, and mild steel has to be 0.118" will thickness and chrome moly 0.083" wall thickness. Mix in the 1.25" rear support (0.118" mild steel and 0.065" chrome moly), and the average 6-point roll bar will be about 1/3 lighter. A 90# mild steel bar will show a saving of about 30# in chrome moly.
A "cage" (under 10.00) is much more complex, but should show similar % savings. In a cage, there are some bars that can bo 0.049" vs. 0.118" in mild steel (
CM 95#
Only 40#....keep in mind this has to be tig welded.....so the price of labor will triple easy.
The strange/ aerospace fron't brake kits seem to take quite a bit off wt. off also, more than a k-member/a-arms.
I would go MS and get some other stuff, unless your going to go really fast.
