water pump?
Old Nov 4, 2015 | 11:42 AM
94Z28LS1toLT1's Avatar
water pump?
Hey guys when I put the water pump back,I'm using the stock wp gaskets ac delco ones from the dealer,do I need any specific silicon when I attach them to the pump. What do u guys recommend
Old Nov 4, 2015 | 01:37 PM
Re: water pump?
You can install them dry or put a smear of non-hardening sealant or RTV on them. Use thread sealant on the bolts.
Old Nov 8, 2015 | 10:51 AM
Re: water pump?
Thank u Rob is black silicon ok to use for the bolts? And is it ok to use the silicon on just the bottom bolts bcuz that's where I noticed the coolant came out of when I took them off
Old Nov 8, 2015 | 02:34 PM
Re: water pump?
No silicone is not ok. Pieces can break off and clog your cooling system. That is why I specified thread sealant. Use on all bolts. Coolant came out of the lower bolt holes because that was where the coolant level was down to.
Old Nov 9, 2015 | 11:22 PM
Re: water pump?
Thank u n I'm sorry ill use thread sealant,gonna be working on it tomorrow thank you again
Fly Z28
Jan 6, 2017 09:58 AM
CurtDrums
Exhaust System
Nov 13, 2015 03:02 PM
Vitamin-E
Nov 1, 2015 08:45 AM
chevyalltheway
Oct 26, 2015 09:24 PM
Camaro91RS
Oct 20, 2015 09:27 PM
