Water only in radiator????
Old Apr 9, 2004 | 03:33 PM
85LT1Z28MEX's Avatar
Judges at the local track want only water on the radiator because it is easier to clean in case of leak...
Will this hurt my engine?
Old Apr 9, 2004 | 03:48 PM
Spinner's Avatar
save rust, it generally isnt a problem as long as your car never sees freezing temperatures. Use distilled water.
Old Apr 9, 2004 | 05:59 PM
Then there is no problem.. the lowest temp we have reached was 53 F and that was to much for us..
thanks..
Old Apr 10, 2004 | 10:26 AM
OBE1 95Z28's Avatar
Short term distilled water is fine. Long term, coolant provides lubricant for the water pump, rust inhibitor for the block and raises the boiling point of the fluid in case you do over heat.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
pimpen1024
Aug 19, 2015 08:36 PM
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
ducttape1975
Jul 10, 2015 06:29 PM
