volts ?
Old Aug 8, 2010 | 07:46 PM
Ocala93TA's Avatar
volts ?
I took a pic ( not the best) but my volts seem to be getting lower and lower every time i drive you can see the needle is on the red and sometimes it gets alittle further , this is sitting at a red light . Does it look like my alternator may be going out ? Thanks for the help
Old Aug 8, 2010 | 07:49 PM
8cylinders>4's Avatar
underdrive pulley?
if you can, try to check the voltage directly from the battery, to see what kind of voltage you are seeing.
in the heat of the summer you will typically see a little less on the gauge but if you see anything less than about 13 volts than you could be having issues with the alternator
Old Aug 8, 2010 | 11:37 PM
If it is getting lower and lower, your alternator is probably not working. Next, your engine won't work, either.
Old Aug 9, 2010 | 07:51 AM
Ocala93TA's Avatar
Theres no underdrive pulley , sounds like this maybe the alternator then .
Old Aug 9, 2010 | 02:28 PM
moondance's Avatar
For my understanding sitting at a light especially with the AC on they will just ride low like that. If its going back up to normal when youre driving down the road its probably good. If its not killing the battery and starting every time there is nothing wrong with it odds are
Old Aug 9, 2010 | 03:24 PM
Ocala93TA's Avatar
yeah thats what its doing , It comes back when i start giving it more throttle
Old Aug 9, 2010 | 03:54 PM
moparman's Avatar
If you haven't done so, take a voltmeter, set to DC, and check the voltage at the battery terminals with the car running.
Old Aug 9, 2010 | 07:37 PM
n2ceptor's Avatar
At the battery, normal temp and idle, volts should read around 13.8~14.2 volts.....
Old Aug 10, 2010 | 08:58 AM
moondance's Avatar
If thats what it is doing and you have no issues starting everything is most likely fine. Mine does the same thing. Did the same thing when I had the old alternator and the new one. I wasted the money getting a new one. If you call GM they will tell you if you have the air on and are sitting still its perfectly normal. As long as no issues starting and it comes back to where it should be when cruising youre fine
Old Aug 10, 2010 | 09:49 AM
MikeGyver's Avatar
Go to vatozone and have them hook up the charging system tester.
Old Aug 10, 2010 | 10:25 AM
razor02097's Avatar
the alternator is probably on it's way out... They can get progressively worse as things wear out. Or they can just go out without warning... Get it tested.
Old Aug 10, 2010 | 09:09 PM
moparman's Avatar
I looked at the voltmeter on my Firebird today, with the AC in max, with blower all the way up. It stayed to the right of the middle hash mark at idle and cruise.
Old Aug 13, 2010 | 08:23 PM
Ocala93TA's Avatar
Picked up a new alternator Problem solved i have juice ! thanks everyone for the help !
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
jackpawt883
Sep 10, 2015 08:53 PM
john-e-boy
3rd Gen / L98 Engine Tech
Feb 19, 2003 06:21 AM
CJ Black LS1 Z28 M6
Middle Atlantic
Jun 15, 2002 10:12 PM
