Vacuum Pump Question
Old Feb 10, 2007 | 09:33 AM
joelster's Avatar
I have seen numerous articles in which these pumps have added 10-20+hp depending on the application. They also state that the pumps themselves suck 5-10hp to turn them and there is a point of diminishing return, in which, if you crank up the vacuum supply, it actually takes more hp to turn the pump then what is gained by the motor. I was wondering if anyone had ever run a vacuum pump off of an electrical motor, such as one that would drive an old-school sbc water pump? This way, you could simply turn the pump on after you do your burnout/before staging, and enjoy the benefits of more hp for your dragstrip pass, then simply shut it off at the end of the run. It would also simplify where you could mount it. You could put it anywhere you want to. You could mount it to the firewall, and run a line into the back of the valve cover or whatever. You would need to experiment to see what rpm, you'd have to spin the pump to have the maximum effect, and then set it up to do this consistently. Discuss.
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
89 iroc zl1
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
