Vacuum?
Old Nov 15, 2006 | 02:20 PM
aifilaw's Avatar
Vacuum?
I finally pulled the stereo out and hooked up the antannae, pretty sure I didn't bump anything, and today I double checked the wiring above it by hand going into the climate control panel.
Anyways, off is off, max-ac is now slightly warm, normal AC is only slightly cooler than ambient air temperature, as is bi-level AC. the heater still works.
Now I would assume that getting the AC charged earlier this summer failed slowly and its leaked out, but that doesn't explain why normal AC is slightly cooler than air temp, and max-ac is actually blows hotter than normal air temp.
Should I be looking for an electrical problem?
Should I be looking for a vacuum problem?
Should I be looking for a freeon problem?
yes I found these, not much help as of yet...
http://shbox.com/1/hvac_vacuum.gif
Old Nov 15, 2006 | 07:24 PM
aifilaw's Avatar
bump
magman
Apr 15, 2016 03:08 AM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
drt
Sep 27, 2015 04:39 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
