Vacuum?
Vacuum?
I finally pulled the stereo out and hooked up the antannae, pretty sure I didn't bump anything, and today I double checked the wiring above it by hand going into the climate control panel.
Anyways, off is off, max-ac is now slightly warm, normal AC is only slightly cooler than ambient air temperature, as is bi-level AC. the heater still works.
Now I would assume that getting the AC charged earlier this summer failed slowly and its leaked out, but that doesn't explain why normal AC is slightly cooler than air temp, and max-ac is actually blows hotter than normal air temp.
Should I be looking for an electrical problem?
Should I be looking for a vacuum problem?
Should I be looking for a freeon problem?
yes I found these, not much help as of yet...
http://shbox.com/1/hvac_vacuum.gif
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
