Upgrade Help
Old Jan 19, 2012 | 07:13 PM
aggieguy13's Avatar
Upgrade Help
what is best spark plug for ls1?
also fixing to have the car repiped with SLP loudmouth mufflers, and SLP Cats. iv heard X-pipe is the best way to go. true?
Old Jan 20, 2012 | 12:12 AM
rv93's Avatar
Re: Upgrade Help
all spark plugs are created equal, more or less. id recommend platinum tipped ones so you dont have to replace them as often. i like densos, but there isnt much difference. and what do you mean about an x pipe being best? you could leave your banks unconnected all the way to the back, use an H pipe, or X pipe. out of the 3 options, x pipes do make the most power. however, unless you get a true dual exhaust, itll be running down one pipe at some point, meaning you dont need any sort of crossover
Old Jan 20, 2012 | 12:25 AM
aggieguy13's Avatar
Re: Upgrade Help
iv heard from a couple sources that x-pipe would be best, as its basicaly stock. theres not enough Flow to fill a Dual setup efficiently
Old Jan 20, 2012 | 12:46 AM
kartracer13's Avatar
Re: Upgrade Help
Basicaly stock is a cat-back system. That's a y into one after the cats and then back to two at the back of the muffler. And as far as (theres not enough Flow to fill a Dual setup efficiently),there is enough flow. If your going to do a true dual all the way back then an x pipe is the best to cut down on turbulence and will flow much smoother.
Old Jan 20, 2012 | 02:31 PM
aggieguy13's Avatar
Re: Upgrade Help
thats what im saying, as in if i were running two independent pipes, with independent cats/mufflers, it wouldnt be as efficient on a stock setup as running an X. yes it would sound nasty, but would have less HP
Old Jan 20, 2012 | 03:54 PM
Tech's Avatar
Re: Upgrade Help
You're missing the point. You really need to look under your car. There is no place to put an x-pipe while keeping a single pipe running back to the muffler.
If you are going to change all of your exhaust, you can add an x-pipe but you will have to run 2 pipes to the rear of the car (or dump them before the axle).
Old Jan 20, 2012 | 05:53 PM
aggieguy13's Avatar
Re: Upgrade Help
i know. lol im OVERHAULING the exhaust. buying new SLP loudmouth II mufflers x2 and a SLP High Flow Cat. as i want to be all matching. and having new piping custom bent. my whole question is if users have done x-pipe and there comments on it
Old Jan 20, 2012 | 06:30 PM
Re: Upgrade Help
Yes,an x-pipe helps with the savaging. In other words it helps pull exhaust out of the cylinder. And yes it will give you more power. An engine is just a big air pump,so if you can help it inhale and exhale easier it will payoff with more power.
Old Jan 20, 2012 | 08:33 PM
aggieguy13's Avatar
Re: Upgrade Help
right. im keeping it all mostly stock to hold the value. only thing i might add other than that is SLP Tru_ram air system
Old Jan 20, 2012 | 09:03 PM
Re: Upgrade Help
The air ram that I have I would recommend to anyone. It's an Austin Preformance super sucker air ram. It's plastic not steel like most of them,so it doesn't get heat soaked,and it works great. The only place I've seen it is ws6project.com
Old Jan 21, 2012 | 04:39 PM
aggieguy13's Avatar
Re: Upgrade Help
dont know anyone lookin for some 3.73 gears do ya?
13qtr
Oct 28, 2016 08:11 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
MDZ28
11
Sep 24, 2015 09:15 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
97SSdude
Aug 21, 2015 09:36 AM
