Update on my 383 buildup!
Old Jun 23, 2004 | 12:02 AM
hot_red_z28's Avatar
Ok, well I figured I would post a little update as to what I have in the works...
I sold the car chassis today and so I purchased a nice bottom end to use as the base for my new buildup... Here are the details...
The bottom end:
Thermally cleaned and Stainless-Steel Shot. Inspected by MPI process. Decked, bored, honed with torque-plates and pressure washed.
Clevite cam bearings
4-bolt main caps.
Eagle 4340 Forged Steel
Eagle Forged 4340 H-Beam, 6" Length, Floating Pin
SRP Forged
Speed-Pro Plasma-Moly
Clevite Main and Rod Bearings
Brass Pioneer Core Plugs
Full Rotating Assembly Dynamic Balancing
ARP main cap studs
Melling High Volume Pump, Pickup Tube and HD Drive
New factory 6-quart oil pan
Rings spaced for slight nitrous use
Compression ratio set to 11:1...
The top end:
GM 847 Cam - 234/242 .575"/.595" on 112LSA
Comp Cams "R" Lifters
Trick Flow Chromemoly Steel Pushrods
Comp Magnum 1.6 Self-Aligning RR's
Comp Cams 978 Springs 150ish seat psi, 400ish nose psi
Lloyd Elliot Stage 2 Heads with Manely Race Flo 2.00" intake/ 1.56" exhaust valves. Flowed 271/187 @.550". 55cc Combustion Chambers.
GM Performance LT1 Carb Intake (Dual plane)
Demon 750cfm 4 barrel with mechanical secondaries
Summit racing 15" air cleaner...
Other/misc: (some still need to be purchased)
Opti delete kit from GM Performance
(Insert brand) distributor
(Insert brand) plug wires
(Insert brand) plugs
(Insert brand) harmonic balancer
Jet-Hot Long Tubes
Any ideas on what kind of power this setup should make?
Also any suggestions on the electrical gear would be nice too...
Old Jun 23, 2004 | 01:36 AM
Spinner's Avatar
Have fun with the golen motor. Turn it to 6800 and I'd definetly see 430 rwhp/tq with a good dyno tune
Old Jun 23, 2004 | 01:39 AM
my goal is anything over 400 to the rear... A 200 shot is in the near future after I get it tuned and running good n/a...
Z Power
Sep 19, 2015 11:19 PM
cristian1311
Sep 12, 2015 08:16 PM
95craz28
11
Sep 12, 2015 07:47 AM
cmsmith
Aug 27, 2015 06:37 PM
alphaauto
Jul 26, 2015 04:40 PM
