shift boot bracket?
Old Jun 22, 2004 | 02:40 PM
coogsLS1's Avatar
shift boot bracket?
where can I pick one up for my car? The plastic square bracket that holds the shift boot in place, busted it when I did my clutch install. I think the dealership wanted too much for it...
Old Jun 22, 2004 | 03:18 PM
DarkRider's Avatar
It seems like a that part would be a dealer only part unless you can find one at a scrap yard but that is pretty doubtful. I would just post in the part wanted sections of some of the f body sites and if you can't get one there then dealer.
Mine busted but I just superglued it back and it works fine
hope this helped
Josh
Old Jun 22, 2004 | 03:21 PM
ucnu112's Avatar
I ran into the same thing. I got some "Plastic Welder" JB-Weld sort of stuff... it works just as well. Heck, it set up wrong the other day, and in trying to break the glue, I broke the bracket instead.
Fred
Old Jun 22, 2004 | 06:13 PM
1995greenTA's Avatar
i went to the dealer last week, and they said it was 119 dollars, i think they had the wrong part, but they couldnt find the right one...so good luck, if you find out where to get one, let us all know!
Old Jun 22, 2004 | 06:23 PM
ucnu112's Avatar
When I checked on 'em, you couldn't get just the bracket; you had to get the leather part too. That's what made it so expensive.
Fred
Old Jun 22, 2004 | 07:36 PM
DarkRider's Avatar
Originally posted by 1995greenTA
119 dollars
You can make your own bracket for less that half that cost I can't justify paying that much for a small peice of plastic
Old Jun 22, 2004 | 09:14 PM
ucnu112's Avatar
best price I found was $85, using my 'connections' @ the local dealership. Otherwise, any junkyard I found wouldn't sell it separate from a console.
Fred
edit: maybe it was $35... I don't recall exactly. Either way, it was too much, and I bought glue
Old Jun 22, 2004 | 09:53 PM
Hyperspeed97z28's Avatar
part # 10271369
GM- its a dealer only item....
shift boot with plastic clip....
I just bought one for my 97, was $42 after tax at my local dealer
Old Jun 23, 2004 | 02:21 AM
Lower's Avatar
Originally posted by Hyperspeed97z28
part # 10271369
The 97-02 part is different item than the (more expensive) 93-96 part. See below for detailed information.
http://web.camaross.com/forums/showt...ght=shift+boot
mattstrike
Mar 11, 2015 07:33 PM
Jason Short
Jan 19, 2015 06:34 PM
danielpetty540
Parts Wanted
Jan 6, 2015 04:56 PM
Hurin
Dec 13, 2014 07:38 PM
