Turn signal/running light fix?
Well, I just discovered my left front turn signal/running light is out. I'm sure it is a light bulb. The actually fix should be easy enough. But getting to the bulb is going to be the hard part. I hope I can do it without removing the headlight assembly.
For those who have done this before, what's the easiest way to change out the light bulb on the left front turn signal? Car year and model in sig.
Re: Turn signal/running light fix?
Well, it was even easier than I could have imagined. No wonder no one replied. All I had to do was unplug the two headlight bulb sockets. Remove a single bolt. Slide the headlight assembly off its brackets. Carefully remove it. Then the turn signal socket and bulb is right there.
Replaced the bulb and reinstalled everything. The whole process took about 15 minutes and I was taking my time.
squarehead
Jan 15, 2015 07:02 PM
squarehead
Nov 21, 2014 08:02 PM
formula79
26
Aug 5, 2002 12:21 PM
