turn signal mount part #
Old Feb 27, 2008 | 07:07 PM
AdsoYo's Avatar
I just broke the plastic piece that the turn signal arm mounts to, does anyone have the part number for this? It is extremely difficult to use the blinker at this point, and using hand signals is really uncool.
Old Feb 27, 2008 | 09:41 PM
Green96Z's Avatar
I think you're referring to the turn signal switch. If so, GM part # is 1995963. But you should be able to find it at Autozone as well.
Old Oct 28, 2008 | 08:26 PM
AdsoYo's Avatar
Just took the car to the dealer and had them do a diagnostic inspection. Apparently the part that broke was the high beam switch (on gmpartshouse it's referred to as a wiper switch); part number 26098535 and he said the lever itself was broken but I haven't had any problems so I don't know what the heck he's talking about. That was P/N 25140743 fyi. The switch is $118.74 at gmpartshouse so I'm gonna dive into this one solo (dealer wanted $930 to fix it).
Old Oct 28, 2008 | 10:02 PM
Green96Z's Avatar
When you pull back on the turn signal lever, it pushes a rod forward that pushes on the headlight switch at the base of the column (exact same place as the starter switch).
http://shbox.com/1/steering_column_exploded.jpg
The rod is #77, and the switch is #83. The switch is cheap (about $12 at Autozone) and easy to replace, but the rod can be a PITA. That price from the dealer is highway robbery, which is why I never let them touch my car.
Old Oct 28, 2008 | 10:29 PM
AdsoYo's Avatar
On that diagram, the piece they said I broke was #23.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
