turn signal doesn't always work
Old Jun 12, 2006 | 09:58 PM
jmsjags's Avatar
Lightbulb turn signal doesn't always work
i have a '97 camaro rs. the running lights work great; both sides stay lit up at all times. the right passenger side turn signal works great. both taillight signals work great. the problem is the front driver's side turn signal. id say about 75% of the time it works fine, but the other 25% of the time when i turn on the signal the light will just go out (no blinking, no running light). im thinking its a problem with the fuse but i really have no clue. any help would be appreciated
Old Jun 12, 2006 | 11:36 PM
Re: turn signal doesn't always work
Probably a poor connection at a socket.
Old Jun 14, 2006 | 03:41 PM
19z28camaro02's Avatar
maybe a flasher has gone bad?
Old Jun 15, 2006 | 12:29 PM
Z28SORR's Avatar
Ditto, check for corrosion at the socket and wire connectors.
Old Jun 15, 2006 | 02:07 PM
ulakovic22's Avatar
That's the problem with mine. I clean it out and it works great for a couple of days and then it stops working. Is there a way to fix it without having to cut and splice in a new socket?
Old Jun 16, 2006 | 11:13 AM
Z28SORR's Avatar
The corrosion is caused by moisture, so anything you can do to keep the socket clean and dry. After I replaced mine, I covered it with dialectic grease. Seems to be holding up fairly well.
stangspank
Nov 13, 2015 01:02 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Injuneer
Dec 15, 2014 09:36 AM
Ryabut98
Sep 3, 2002 11:45 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
