turn signal bulbs keep going bad
Old Feb 1, 2008 | 02:07 PM
tiafn2's Avatar
Anyone else have issues with their front turn signal bulbs burning out repeatedly? I have a 2002 Firehawk and about a year ago one of the front turn signal bulbs went bad. I put in a new bulb (a cheap one from autozone) in and a couple weeks later its gone bad. Get another bulb and it goes bad in a couple weeks. So at this point I figure I'll get the "higher quality" bulbs (made by Philips I think). But same result as the cheap ones. Looks like most times part of the metal connection is breaking off the base of the bulbs. Don't know what's causing it but it's happening to both front turn signals.
Is there a manufacturer that makes a better quality bulb?
Old Feb 1, 2008 | 02:17 PM
00ls100's Avatar
this would be good info to know. my lights in the rear of the car ALWAYS go out. it's irritating
Old Feb 1, 2008 | 02:36 PM
PSU 98's Avatar
Are they aftermarket lenses? Is there water getting into them around the seals? Are the sockets very black? You may want to try some dielectric grease on the connectors when installing the new bulbs. I had similar problems with an old Camaro I owned.
Old Feb 1, 2008 | 04:07 PM
Need4Camaro's Avatar
Likewise, solved it by literally ducktaping the assembly of the bulbsocket to the lenses so there was no way water could get in...
To the OP... Are they failing right after it rains? If they are, it's undoubfully moisture... Find a way to form a tighter seal, go all out and ducktape it if you have to
Old Feb 19, 2008 | 03:39 PM
tiafn2's Avatar
Yeah I've completely sealed it off from any water getting in with silicone. i even sprayed it with a garden hose just to make sure it's watertight. It seems like everytime a bulb fails it's because the metal connectors at the base are breaking off. and they break off with or without the dielectric grease on there. that's why i was thinking it's a quality issue with the bulbs.
Old Feb 19, 2008 | 03:47 PM
ss.slp.ls1's Avatar
New sockets aren't a budget breaker, put a new one in and see if your bulb lasts longer. Good luck.
stangspank
Nov 13, 2015 01:02 PM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
CMJ917-95CMO
Jun 19, 2002 09:10 PM
