Transferability?
Old Feb 26, 2009 | 10:32 AM
KajunKadillac's Avatar
Transferability?
I was wondering how much could be swapped between a '94 v6 camaro and a '96 z28? Reason for this cause i might have a compromised structure on my z, and was wondering if i can get a v6 model and swap the suspension, engine (and harness), brakes etc... into it, are the fuel pumps the same in both models? as well as the fuel lines? Or would the work just not be worth it? and is there a possibilty to help strength my damaged frame rail on my Z ie welding some sheetmetal, and subframe connectors?
Old Feb 26, 2009 | 11:12 AM
teke184's Avatar
they are the same car....so bascially everything will transfer.
i think you'll have to play with the brakes a bit due to possibly having drums on the v6 model.
wiring may be a bit messy...but if you pull the whole harness out of the 96 it should be fine.
might be easier though to get an aftermarket harness and run all the stuff new. i'm sure painless wiring makes a kit.
MDZ28
Sep 7, 2015 09:16 PM
WPHIG2
Aug 27, 2015 06:37 AM
MJ_Z28
Apr 29, 2003 10:28 AM
Hawk
Mar 2, 2003 10:19 PM
Serial Thriller
Feb 18, 2003 12:46 PM
