Traction Controll Problems! Please Help!!!!
Old 02-18-2006, 07:00 PM
BadLS1's Avatar
Well there is somethin wrong with my traction controll and it wont turn off, so i un hooked the abs sensor so it at least wouldent kick the pedal back, but ive tried the basics like replacing the abs sensors and the switch and it still isnt working, so is there a way to just completly eliminate the traction controll.
BadLS1 is offline
Old 02-21-2006, 07:01 PM
BadLS1's Avatar
Re: Traction Controll Problems! Please Help!!!!
I know that someone on here has to know somethin on either how to get rid of it or fix it
BadLS1 is offline
Old 02-21-2006, 07:17 PM
Dave89IROC's Avatar
what do you mean it wont turn off, you mean the switch is not working?
Dave89IROC is offline
Old 02-22-2006, 04:27 PM
BadLS1's Avatar
It does nothing when you hit the switch (it doesnt Say ASR off and the switch doesnt light up) so im driving around with my ASR permanantly on i can figure out how to fix it so i just assume eliminate it if i can
BadLS1 is offline
Old 02-22-2006, 07:39 PM
Dave89IROC's Avatar
might be a bad switch
pull the switch out, unplug it, the jump the wires together, see if it goes off them(the switch is just a momentary switch)
Old 02-23-2006, 12:13 PM
BadLS1's Avatar
I have Replaced the switch and still nothin happens
BadLS1 is offline
Old 02-23-2006, 04:41 PM
Dave89IROC's Avatar
then you need to make sure the wires leading from the switch to the EBTCM are good
dluna333
Parts Wanted
03-06-2015 07:11 AM
Jlo
02-03-2015 09:41 PM
squarehead
01-15-2015 07:02 PM
ddr698
01-09-2015 10:05 AM
07-04-2005 05:00 PM
Quick Reply: Traction Controll Problems! Please Help!!!!
