Traction Controll Problems! Please Help!!!!
Old Feb 18, 2006 | 07:00 PM
BadLS1's Avatar
Well there is somethin wrong with my traction controll and it wont turn off, so i un hooked the abs sensor so it at least wouldent kick the pedal back, but ive tried the basics like replacing the abs sensors and the switch and it still isnt working, so is there a way to just completly eliminate the traction controll.
Old Feb 21, 2006 | 07:01 PM
BadLS1's Avatar
Re: Traction Controll Problems! Please Help!!!!
I know that someone on here has to know somethin on either how to get rid of it or fix it
Old Feb 21, 2006 | 07:17 PM
Dave89IROC's Avatar
what do you mean it wont turn off, you mean the switch is not working?
Old Feb 22, 2006 | 04:27 PM
BadLS1's Avatar
It does nothing when you hit the switch (it doesnt Say ASR off and the switch doesnt light up) so im driving around with my ASR permanantly on i can figure out how to fix it so i just assume eliminate it if i can
Old Feb 22, 2006 | 07:39 PM
Dave89IROC's Avatar
might be a bad switch
pull the switch out, unplug it, the jump the wires together, see if it goes off them(the switch is just a momentary switch)
Old Feb 23, 2006 | 12:13 PM
BadLS1's Avatar
I have Replaced the switch and still nothin happens
Old Feb 23, 2006 | 04:41 PM
Dave89IROC's Avatar
then you need to make sure the wires leading from the switch to the EBTCM are good
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
