Torque Wrench suggestions
Old Mar 19, 2006 | 12:41 PM
ls1_bc's Avatar
I don't have my own torque wrench Is there one size or model that will cover most jobs on our cars or do I have to buy a couple of different ones. I need it to do everything from plug changes to some suspension work. I'm no pro so will not get used that much so don't need anything super heavy duty. And of course buget is always a consideration.
Old Mar 19, 2006 | 01:03 PM
2000GTP's Avatar
Re: Torque Wrench suggestions
I have 3 Craftsmen torque wrenches, each serves its own purpose. I have a 1/2 drive in ft-lbs, a 3/8 drive in ft-lbs, and a 3/8 drive in inch-lbs. I usually use the 3/8 drive ft-lb torque wrench for most of my duties that are either engine or suspension related.
Old Mar 19, 2006 | 01:33 PM
resurrectedz28's Avatar
I just got a 1/2 drive from oreily's. Couldn't shell out the big bucks for a craftsmen tho, so i got some off brand, but it seems to work fine so far.
Old Mar 19, 2006 | 02:11 PM
StephenDeli22's Avatar
I have a ratcheting 1/2 inch drive torque wrench. It is really nice. It beats the hell out of my other torque wrench with the needle. It was 75$. The wrench might be a bit long for doing plugs though...
Old Mar 19, 2006 | 03:42 PM
lt11997's Avatar
I have a 1/2 Snap-on one that goes from 50-250 ft. lbs(don't use it that much), 3/8 craftsman 10-75 ft. lbs. (I use this one the most and it's on sale right now for $65 at sears) and I also have a 3/8 craftsman inch lb.
Old Mar 19, 2006 | 04:36 PM
Lower's Avatar
I bought a pair of cheap beam and needle type Craftsman from Sears.
A 3/8" that goes to 75 ft/lbs for most repairs, and a 1/2" that goes to 150 ft/lbs for suspension and lug nut type repairs.
Are they highly accurate? Probably not. But I paid like $20 a piece for them, and I'd bet (since they're Craftsman) that they're accurate enough for use if well taken care of.
Old Mar 19, 2006 | 10:05 PM
revtime's Avatar
I have found that if your halfway serious about working on the car you will need a ft lb and an inch lb torque wrench.
You can do what I did and buy a 1/2 inch ft lb wrench and use a reducer so you can use 3/8 sockets on it.
The inch lb torque wrench actually comes in real handy at times.
Victor Lamb
Aug 26, 2017 02:52 PM
blmw
Jun 14, 2015 05:20 PM
KYWes
Apr 3, 2015 07:59 PM
cyteone
Feb 7, 2015 06:04 PM
veryslowfbody
Aug 22, 2002 04:31 PM
