tires
Re: tires
Did you review the FAQ in the "Wheels and Tires" forum. The mods required to put 315's in the rear are minimal. 275's or 285's will fit in the front. Of course they will require wheels with the correct combination of width and offset.
Re: tires
What was the full size spec of the tires (295/xx-xx)? Generally, that only happens when you go to or exceed a 28" tire diameter, in particular with non-radial slicks. Street tires are typically closer to 26" diameter.
Re: tires
