Tire size
Old Jun 1, 2004 | 08:42 PM
SantaCruz163's Avatar
Tire size
What size tires will fit a 17x11 wheel and 17x9.5 wheel? I'm not looking for anything crazy just a nice all around tire. What size tires will fit on a stock 16" F body wheel, i plan on buying 2 DR for the stockers down the road.
Old Jun 1, 2004 | 08:49 PM
sabre81's Avatar
no bigger than 255's on the rears safely.
Old Jun 1, 2004 | 08:51 PM
psychocabbage's Avatar
your 17" will hold anything fro m 275 (what stock 17"s run) to 315(with mild hammering)
your 16" will run 245-255..
Nittos make 245's
BFG DRs are 255's
Old Jun 1, 2004 | 08:55 PM
sabre81's Avatar
yes no larger than 255s on the 16" stocks i meant
Old Jun 1, 2004 | 08:58 PM
I'm not good with tire sizes so bare with me. Will a 275/40/17 fit alright on a 17x9.5" wheel? I am going with Torque Thrust IIs. I was thinking about 17x11s in the rear but that might be a bit too much and I can't rotate tires and are $$. What is a good brand tire that is not too expensive but serves its purpose?
Old Jun 1, 2004 | 09:01 PM
unvc92camarors's Avatar
go 275s on your 17x9.5 and 315s on the 17x11 if you get them
stock, don't go above 255 like sabre81 said
i would just do 245 instead of paying for an extra 10 cm
jmo
Old Jun 2, 2004 | 12:38 AM
96lt1Camaro's Avatar
jmo
I believe is 10 mm not 10Cm. 245Cm of tire is alot like 2.5 meters!!! hehe. So its 245mm or 255 mm
Just thought i corrected that
Old Jun 2, 2004 | 07:07 AM
doh!
sorry about that, i meant to say 10mm
thanks for correcting
haha, 2.5 meters of tire, now that'd be nice for traction
Old Jun 2, 2004 | 10:48 AM
The best tires for the $$ that I have found (and consider that I have tested everything worthwile from Dunlop, Yokohama, Pirelli, Kumho, Nitto, BFG, Goodyear..)
I say the Yokohama AVS ES100's stand out as the value leader.
When $ is an issue these are your tires..
Simple psycho math here:
Buy cheaper tires + Get better traction = Harder driving
Harder Driving - Wear = Need for new tires sooner
Buy tires more often but spend less then you are running a newer tire more often.
You end up with a safer ride with killer performance.. I am at just under 15K miles on my AVS ES100s. You can tell the difference in how my driving has become more aggressive since I have feathered the front tires from pushing hard in turns. After a rotation its all good. I am very happy with these and will be getting them again.. Probably at about 20K mile mark.. My GSC's lasted 28K miles. I do run at the track but do not do burnouts. I do also push the car hard but never abuse it. Tires usually last me a decent amount of time.
For a high end tire, my Pirelli P Zero rock! I love those tires.
HectorM52
Jul 30, 2017 11:46 AM
Fastbird93
Apr 9, 2016 07:01 PM
LD Kirk
Apr 30, 2015 08:54 AM
blac94Z
Mar 6, 2015 07:55 AM
cristian1311
Mar 4, 2015 04:45 PM
