O2 sensor help????
Old Jun 1, 2004 | 02:23 PM
ss400hp's Avatar
O2 sensor help????
How bad would a bad O2 sensor hinder your performance, my car is ******* lately and I know2 one is bad , I ordered O2 simms and I dont know what else the problem could be, any6 ideas????
Old Jun 1, 2004 | 10:26 PM
valter's Avatar
Post-cat O2 sensors will not hurt performance - it's for measuring efficiency of cats. So sims will not help you if your pre-cats sensors is bad. They are only useful to avoid SES light (it can be done with programming too). Performance can be severely affected by bad pre-cat O2 sensors, most common thing - running a way too rich and rough. What year is your car?
Old Jun 2, 2004 | 08:13 AM
ss400hp's Avatar
the car is a 2000 , I think it is a pre cat one that is bad all the other ones have a white tip and the one is all black so Im guessing its bad cuz the car is throwing the cat code obviously with no cats
Old Jun 2, 2004 | 09:00 AM
valter's Avatar
Be sure to replace pre-cats O2's both together and with Delco's. Bosch worked fine for me, but for a very short time
Old Jun 2, 2004 | 10:56 AM
The "cat code" isn't going to cause a pre-cat sensor to be "all black". Excess carbon buildup would point to an excessively rich mixture. You most likely have something causing it to run excessively rich. A detailed scan log, focusing on the long term fuel corrections, by Cell, might point you in the correct direction.
generaldave
Sep 25, 2015 06:48 PM
98-LS1Z28
Sep 8, 2015 03:12 PM
350350
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
Aug 7, 2015 01:26 PM
