Which of these mufflers are a straight through design?....
Old Jun 27, 2004 | 09:57 PM
PureMuscle
Guest
Posts: n/a
I have been listening to a lot of sound clips with different kinds of exhaust systems installed on stock LS-1's to get a good idea what sounds deep and the least raspy. I know this is always an opinion based question but out of Magnaflow, Hooker, GMMG, and SLP which have straight through designs and a deep sound to them. Some of the ones I have listened to get a little raspy and distorted as the rpm's increase. I know it's hard to judge by sound clips so what are your experiences with these exhaust and any others you might recommend.
Old Jun 27, 2004 | 11:06 PM
codster11's Avatar
I have flowmaster right now, everyone rags on it, cause it doesnt flow as well as some others, but I also have hooker lt's with ory, and i think it sounds pretty bad ***, a little rasp high up, but nothing too bad, i like it and have had many compliments on it.
Old Jun 29, 2004 | 07:09 AM
newWolforder's Avatar
deffinitely Magnaflow just put the catback on my car sounds sweet and freed up a ton of restriction think the only restriction I have now is my cat
Old Jun 29, 2004 | 01:20 PM
Red96Lt1's Avatar
A glass pack is the only straight flow design that I know of. You can look right down it.
Old Jun 29, 2004 | 02:12 PM
Lower's Avatar
Re: Which of these mufflers are a straight through design?....
Would you care to give us your definition of "straight through" for us? I ask becauseas I recall (and I could be wrong), straight through defines how the pipes come out of the muffler. You can have a straight through design, or a cross flow design.
All are deep sounding muffler systems.
Straight through means the inlet comes in one end and the outlet(s) come out the end, where cross flow would mean that the inlet comes in one end, and the outlets are on ends -one on the same end as the inlet and one on the opposite.
Straight through as a muffler term doesn't mean unobstructed -just less turbuloent.
The Magnaflow and Hooker are crossflow traditional shaped mufflers.
GMMG uses dual bullet mufflers, and the SLP -the Loudmouth at least, uses a single bullet muffler -IIRC.
I'd suggest you poke around all the applicable websites and have a look at the designs. (Be warned most Magnaflow pictures show a "stock" photo with a true straight through design, while the real system for LT1 and LS1 cars is a crossflow design).
Quickss96
Jan 29, 2016 05:56 PM
NewsBot
Aug 21, 2015 09:40 AM
karpetcm
Aug 14, 2015 03:02 PM
Aug 5, 2015 08:35 AM
NewsBot
Aug 3, 2015 02:40 PM
