Which Terminal In Connector-Alt. Field?
Old Sep 8, 2007 | 02:35 PM
stingray69's Avatar
Trying to finish minor things on a TPI swap into '78 Camaro. The alternator connector has 4 small and one large terminal.
Due to having to reroute column connector wires to accommodate the digital guage package (ancient Cyberdyne), I am running a dedicated ignition power wire to a circa '87 TPI alternator, at least I think its '87 TPI...Had been told to use the second terminal of the four smaller ones in the connector, only, nothing else needed-but this doesn't seem to do it.
In looking at diagrams, it seems that some had a jumper form the large wire to one of the terminals, and ignition power was to go to another terminal-but it seems that EVERY application is different...different terminals in each one.
My understanding was all I needed to do was run ignition power to the second terminal, and no jumper needed from large wire in connector to any small terminal.
How can I find what it takes to do this without risking just burning it up?
By the way, an alternator shop had told me to use the second small terminal, when I had burned up the regulator by mistakenly feeding it battery power. 6 years later, I find that this isn't working...
Can anybody steer me right?
68camaroboltz
Oct 5, 2015 01:46 PM
jerrysims71
Aug 15, 2015 12:47 PM
gelbza
Jul 12, 2015 08:10 AM
nosliw
Feb 7, 2015 01:30 PM
rage366
Jan 31, 2003 01:03 AM
