temp gauge stuck 95Z ??
Old Jul 15, 2009 | 09:41 PM
Grant from NC's Avatar
Its not moved in the last 4 months. It seems to be stuck at around 120
What wires should I check? Whats the best way to remove the instrument cluster.. Where are all the bolt heads??? I need some help on this one.. thanks
Old Jul 15, 2009 | 10:59 PM
Disconnect it from the temp sensor, first and see what the gauge does. Check the wire to the sensor and make sure it is not grounding out.
http://shbox.com/1/temp_sensor2.jpg
http://shbox.com/1/4th_gen_tech2.html#ect
Old Jul 16, 2009 | 06:45 PM
still stuck
I pulled the green (in my case) wire off at the sensor on engine block and tried the switch. It still did not move. Switch on or off, wire on or off, its seems to be stuck in the first mark above the 160.. what should I try next... I want to pull the dash down, but seems like a lot of work? Is it.. I see the first few screws below the steering colume. I am assuming it drops enough to give me access to the bottom screws in the main dash trim to get to the instrument cluster? Am I right??
Old Jul 16, 2009 | 10:07 PM
You don't have to tear the entire dash down to pull the instument cluster. Remove the bezel and the cluster should unscrew and pull right out.
Old Jul 21, 2009 | 07:06 PM
Panel Bezel off
What the process for taking the instrument cluster bezel off. I seen some of the bolts in the glove box for the radio bezel, then what???
Magenta_Hearts
Mar 29, 2017 08:54 PM
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
