temp gauge broken?
Old Sep 15, 2014 | 11:00 AM
  #16
Re: temp gauge broken?
You need to run a 50/50 mix of coolant. That raises the boiling temperature, and prevents boiling in the radiator or engine.
You can buy a hydrocarbon test kit at an auto parts store. Works in water or in the 50/50 mix. It is used to determine if the head gasket is leaking, forcing combustion products into the coolant.
Old Sep 28, 2014 | 08:12 AM
  #17
jj71787's Avatar
I took it to pep boys and the guy did a carbon monoxide test. He said it was supposed to turn yellow and it didn't. Then he said it's a blown head gasket just by looking at it.
He said there's no pressure in the hose.
Old Sep 28, 2014 | 09:22 AM
  #18
A head gasket leak leading to loss of coolant is going to contaminate the coolant with combustion gasses. Hard to rationalize the fact that he found no CO, but by looking at "it" (whatever "it" is) he determined it's a leaking head gasket. Was "it" the coolant, and did he see an excessive amount of bubbling in the coolant?
He said there is no pressure in what hose?
Might want to read this for more info:
How to Test for Head Gasket Failure
Old Sep 28, 2014 | 02:46 PM
  #19
jj71787's Avatar
The water in the radiator was bubbling. But all he did was say that and the no pressure in the hoses was a definite head gasket
Old Oct 13, 2014 | 11:20 AM
  #20
jj71787's Avatar
The problem was fixed and simple. The radiator was just very dirty.
I do have another issue though. My clutch was bad and my girl's cousin looked at it and he sid he can replace the clutch for $625. Then he says he cant because the brakes are bad and he can't test it.
I think this guy is jerking me around. The brakes work fine. I even just put a brand new brake line on and bled the brakes, but he insists the car is locking up.
Old Oct 13, 2014 | 02:42 PM
  #21
Might want to avoid using Pep Boys for your mechanical work in the future.
Old Oct 14, 2014 | 05:41 PM
  #22
jj71787's Avatar
Definitely
dylan1303
May 22, 2015 12:24 PM
Biggiebound
Apr 21, 2015 11:28 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
