tail light bulb
Old Nov 16, 2006 | 06:40 PM
camzaro28's Avatar
tail light bulb
i did the search, didnt find anything.
on my driver side tail light the very outside bulb is out. so i take the light fixture out and pull the bulb out. go to take the bulb by itself out from whatever is holding it inside, and it seems to be 1 complete assembly!
so do i have to buy the bulb assembly from GM? with the wires coming out of it? or am i missing something?
TIA
[IMG][/IMG]
Old Nov 16, 2006 | 06:45 PM
ImportKILLER's Avatar
Rotate the bulb counter-clockwise 90 degrees and it should come out with a gentle pull.
So no, you do not have to buy the whole assembly...just the bulb.
Old Nov 16, 2006 | 07:00 PM
camzaro28's Avatar
now that is what i did to all the others, but this one on the very outside seems to be different. the bulb is tiny and is sunk into the assembly. ill get a pic here soon.
thanks though
Old Nov 16, 2006 | 09:10 PM
That one just pulls out...I believe it is a 194 bulb or some other mini bulb.
No twisting or anything...just pull it out. You may need to gently wiggle it a bit since its likely been in there for a few years...but it'll come out.
Old Nov 16, 2006 | 09:52 PM
Dave89IROC's Avatar
it is a 194 bulb
the rubber of the socket is probably melted to it, if needed, take a sharp knife and cut the bulb loose
Old Nov 16, 2006 | 10:00 PM
ROCK HARDSON's Avatar
it's a 194 bulb, just like your license plate bulb.
Old Nov 16, 2006 | 10:27 PM
n2ceptor's Avatar
You could use a 168 (3cp) The 194 is 2cp.... But the 168 only has half the life of a 194....
Old Nov 17, 2006 | 09:20 AM
camzaro28's Avatar
ok guys, that bulb had me stumped. but my excuse, due to all the condensation built up and it being in there so good, i was pulling on it hard as i could without squeezing it and it busting.
so anyway, once my it dried out this morning i got it out.
well thanks for the help guys.
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
mattstrike
Mar 24, 2015 02:11 PM
CaRParts102
Dec 6, 2014 08:45 AM
JoFerZ
Aug 31, 2003 12:49 AM
