t-tops keep leaking and i cant take it anymore
Old Dec 29, 2010 | 01:09 PM
  #46
MustangEater82's Avatar
Re: t-tops keep leaking and i cant take it anymore
Originally Posted by fade96
You can use black silicone to fix the leak. You will need, black silicone and non-stick plastic wrap.
1. Identify where the leak(s) are coming from.
2. Remove t-top(s)
3. Goop on a liberal amount of silicone.
4. Cover the silicone with the plastic wrap.
5. Re-install the t-top(s) and lock them in.
6. Let dry overnight.
7. Remove t-top(s)
8. Remove plastic wrap.
The silicone has now formed to the low or missing spot in the weatherstripping.
If you put a LOT of silicone, you may have to trim the excess with a razor blade.
Hope this helps.
This is the majority of everyones leaks. People think its the t-top to weather tripping connection... its not.
the water goes in that channel... works its way ot the edge where the latch is, it is supposed to go up the rubber and down the drain tube to the bottom of the door.
So make sure drain tube isn't blocked...
Make sure there is a seal beneath the weather stripping at the point where the latches are, if there is a poor seal the water just goes UNDER the weather strip and ends up in the car, its water, its not going to bypass the path of least resistance and go slightly uphill to a drain tube.
I did a t-top conversion, didn't have time to seal, it but I did everything else... It rained all day the next day, looked like easily 1-2 gallons of water in my car. I kept towels on the roof for a few days while it rained once it dried up I siliconed it up, all leaks stopped. Was leak free for years, rain, power wash, car washes...
I take it back there was a slight leak form horizontal high pressure water on the passenger side only where the t-top seal met weather trip, but it was a rip in it. And only a slight dribble and only from power washing water sideways, never from rain.
Has almost nothing to do with subframes, hell I think the vaseline, rubber seal gasket does nothing as well in terms of leaks... It is that critical point where the water needs to be directed to the drain tubes.
I thought this was common knowledge....
as for structural integrity.... All cars are t-top cars from factory, they just tack weld a piece of metal over the window for a hardtop, I woudl not say it adds any structural integrity, and I do not think its much lighter, the t-tops way about as much as the hunk of metal cut off, if its any difference less then 5-10 lbs total.
Old Mar 28, 2022 | 05:15 AM
  #47
Marks04SS's Avatar
I bought a new 82 Z pace car. WHAT A PIECE OF CRAP.......... I had it back to the dealership 16 times with t-top leaks. Too bad too because I had a 78 Z28 (a real camaro)
Good
and did nothing but brag about it and it was a babe getter. I was worried in 82 to go on a date for fear of it starting to rain. The 305 TBI was equal to the crap of the T-tops. WHAT a DOG. I have a 04 Monte Carlo SS 3.8, not even with the turbo and IT could out run the 82 Z. Sorry, dont feel like the 82 deserves to be called a Z-28
Alien
Jun 27, 2015 01:13 PM
QuickSilver02
Apr 7, 2015 11:12 AM
LastChance719
Cars Wanted
Feb 16, 2015 11:03 AM
Brake_L8
Jan 20, 2015 09:44 AM
The Seer
Nov 20, 2014 06:32 AM
