T- top help
Old May 22, 2004 | 10:14 PM
camaro325's Avatar
T- top help
I have a water leak between the edge of the ttop and the top of the side window, I washed my car the other day and when I looked inside, the driver side and passenger side seat were all wet on the outer edge......what do you think coulod be the problem.
Thanksalot
Old May 22, 2004 | 10:29 PM
Z28WannaB's Avatar
I don't have t-tops, but deductive reasoning leads me to conclude that most likely the weather stripping has worn away and needs to be replaced. Also, this question has little to do with LT1 specifics and thus should be placed in the F-Body discussion forum.
Any time a car leaks, you can usually find that the source is caused by that rubber stuff on the outside of the leaking area AKA weather stripping.
- Z28WannaB
Old May 23, 2004 | 12:01 AM
carlos64030's Avatar
Take the tops off and reinstall them and make sure that the seals are overlapping each other on each trailing edge...(body seal over t-top seal).
Old May 23, 2004 | 12:18 AM
99blackSS's Avatar
When that started happening on the V6 Camaro I took it into a body shop and they said that it is a common problem with t-tops. They just adjusted the windows to make them go up a tiny bit higher to form a tighter seal, they didn't even charge me for it.
Old May 23, 2004 | 12:40 AM
Slappy3243's Avatar
Re: T- top help
Thanksalot
Also, make sure that you don't directly spray the seals with the hose or they will leak.
Old May 23, 2004 | 11:56 AM
JoeliusZ28's Avatar
Once in a while mine leak where the window, windshield, and t-top all come together. I usually have to spray it directly for it to leak though. so when I wash my car I just shut a crumbled up paper towel in the door on each side.
Yes, Yes, I know... I spare no expense when fixing a leak
Old May 23, 2004 | 09:59 PM
camaro325's Avatar
thanks but I think I figured out the problem.......the weather seals in between look to be molded in from being so old, so it doesn't reallyt form a tight seal anymore between the window and t top
Old May 24, 2004 | 07:07 PM
SFB767's Avatar
My t-tops leak now and then too and I've tried everything from rubber cement to carrying a paper towel with me in case of rain.
The best fix I have found so far is black electrical tape. My t-tops leak on the top of the driver's window and the water trickles down during a downpour or if I spray that area hard when I'm washing the car.
The window doesn't push hard enough against the weatherstripping AND the slit where the back of the t-top meets the car's weatherstripping is also a vulnerable area for a leak too.
The tape fix DOES work, but the only drawback is you have to remove the tape everytime you take the t-tops off and reapply new tape when the t-tops go back on. You may also want to apply multiple layers of tape to ensure a tighter seal when the window is up. The tape is less than a dollar and it's not even noticeable, give it a try.
Old May 24, 2004 | 07:18 PM
Lt1 and Ls1's Avatar
Wow I am glad I ordered mine a hardtop
Old May 24, 2004 | 10:53 PM
99blackSS's Avatar
It's easily fixable if it even ever occurs. Definitely not a big enough reason for me to not get t-tops.
Old May 24, 2004 | 11:59 PM
camaro325's Avatar
same here, I wouldn't want it any other way but with t tops
sleeperZ96BT
Sep 9, 2015 08:28 AM
Rittmeister
Aug 7, 2015 01:13 AM
Aug 5, 2015 08:35 AM
Boss002
Jul 24, 2015 10:47 AM
hcarrickz3
Jul 21, 2015 08:46 AM
