Swap from 93-96 cluster to a 97+ cluster?
Old Mar 23, 2005 | 04:00 AM
FuryZ28's Avatar
Does anyone know if the 97+ gauge cluster uses the same connectors and would work with a PCM from a 93-96 camaro? I know they're different shapes/sizes, but I plan on replacing my entire cluster, dash, and center console from my 93 Camaro to a 97-02 setup. I like the 97+ center console better, but if I can recall, I don't think it would work as a direct replacement with a 93-96 dash design, which is why I am looking into replacing everything. I like the 97+ gauge cluster better anyways. Can anyone offer some helpful information here?
Old Mar 23, 2005 | 05:21 AM
Fastbird93's Avatar
Re: Swap from 93-96 cluster to a 97+ cluster?
Seeing as how you're a 93, this was just discussed over on www.speeddensity.org. The thread is here.
Basically, a 97 cluster WILL work. On the 93, and 93's only, you much remove the tach filter in order for the tach to work correctly. It's a little box located in the wiring harness right near the coil. What you will have to put up with though, is a constant on Fasten Seat Belt guy and TCS OFF light. It's easy enough to disassemble the new cluster and block off those lights though. Also, aparrently there's a shop in the DFW area that CAN reprogram the digital odometer now, but they must have a notarized odometer verification form from your car with the current mileage on it in order to legally accomplish the odometer reprogram. Cheap though, only like $40-50 bucks if I remember right.
Old Mar 23, 2005 | 05:42 AM
FuryZ28's Avatar
So, only a 97's will work, right? 98-02 uses different connectors or requires a different PCM? Remember that the 97's have the same interior as the 98+...
Old Mar 23, 2005 | 04:37 PM
Fastbird93's Avatar
Right. The ONLY ones with the digital odometer that will work are the 97's.
Old Mar 23, 2005 | 06:13 PM
FuryZ28's Avatar
How does that work though? I mean, if the original odometer is analog, what wires into the new digital one??
Old Mar 23, 2005 | 06:45 PM
mourningyou's Avatar
as far as i know (and thats not saying much) an odometer is a sealed unit. it just receives so many "pulses" for each mile, and increments itself. the "analog" odometer should still be electronic, it just has an analog display, whereas the digital one substitutes led's for the number wheels.
Old Mar 23, 2005 | 09:37 PM
Fastbird93's Avatar
Hell, I don't know how it works. But it does. My purple 93 has a 97 digital cluster in it, and I've got another digital cluster for my black 93 that I"m waiting to put in until it's been reprogrammed.
Old Mar 23, 2005 | 09:56 PM
FuryZ28's Avatar
Was it hard to swap all the dash parts over??
Old Mar 24, 2005 | 05:03 AM
Fastbird93's Avatar
The cluster is just plug and play (with exception to the 93 tach filter removal). Just pull the bezel straight off, remove the four ( I think, been a while since I've been in there) retaining bolts from the cluster, pull the old cluster out and detach the wiring harness, then put the new one in, in reverse order.
Old Apr 17, 2006 | 07:58 PM
BadAssed93Z's Avatar
i know this is an old post but... how exactly do you remove the tach filter. do you connect the 2 white wires and ground the black or what?
thanks
-Grant
Old Apr 17, 2006 | 08:04 PM
Z95m6's Avatar
You can't really listen to Fastbird93 because he has a Bird and the clusters are pretty much exactly the same from 93-97. Expect to spend most of a day swapping out the dash rearranging the cluster plug and rerouting everything. If you want to you can get a 93-97 TA/Bird cluster and its wired the same as a 97+ Camaro console and will bolt right into the 97+ dash.
David Dempsey
Mar 12, 2016 12:42 AM
blac94Z
Nov 4, 2015 01:59 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
