Suggestions on my next mod.
Old Jan 30, 2006 | 02:03 PM
LtsRace's Avatar
What should I do to my car next? im thinking on head/cam/roller rockers. But is there anything i can do in the meantime while im saving up cash? Any small things ive missed? SEE SIGNITURE for list of mods...
Old Jan 30, 2006 | 02:17 PM
MyShibbyZ28's Avatar
Re: Suggestions on my next mod.
Shocks, springs, LCA, swaybars.
Old Jan 30, 2006 | 02:23 PM
Critter's Avatar
gears gears gears...a4 go with 3:73's....
other than that...looks like your done with the bolt ons
Old Jan 30, 2006 | 03:20 PM
RedHottG2's Avatar
160* Hypertech stat, weld in SFC's that's all I can think of right now that don't cost very much.
Old Jan 30, 2006 | 03:23 PM
LtsRace's Avatar
Already got the 160 stat. Dont think I can do subframe connectors or springs due to my exhaust (
Old Jan 30, 2006 | 05:00 PM
Critter's Avatar
u can't i have the same problem with mine
Old Jan 30, 2006 | 05:11 PM
2000GTP's Avatar
A heads/cam swap will add up to quite a lump sum of money, you might just want to focus all your dough on that.
Old Jan 30, 2006 | 06:46 PM
LtsRace's Avatar
Besides the obvious head/cam package, what other major cost condiserations are there to take?
Old Jan 30, 2006 | 06:51 PM
2000GTP's Avatar
Injectors, throttle body upgrade, gasket kit, pushrods, lifters, rockers, head bolts, timing chain,rocker studs, possibly guideplates depending on your rockers, and its also a good time to replace the opti-spark if it is getting worn. Also, factor in some coolant, oil, and the other odds and ends as well as maybe a fresh set of plugs and wires. It can add up real quick.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
tommalcolm
Sep 11, 2015 03:39 PM
Bxlt1
Sep 10, 2015 08:16 AM
