starting problem, very slow crank then clicking.
Old Feb 13, 2012 | 05:09 PM
SkiBumDreams's Avatar
tried to start car it cranked very slowly then started to click. the car had not been started in 3 or 4 days and the temps here have been in the teens. jump started car without any problems and let the car run for a good long while. watched volt gauge inside car. it read high like it was charging waited til it dropped to normal operating level on gauge then turned off the car. i did check the alternator (while gauge showed charging level while car was running) at the post and a bolt on the bracket and it was showing 14.5 volts, checked at battery terminals and it was the same. battery is less than a month old interstate megatron2 and alternator is 4 months old.
24 hours later
-car slowly cranked then clicked, no start
-battery 'dead' read 10.5 volts
-looking for parasitic drain(batt cable unhooked meter between cable and batt terminal)
-heard headlight motor make very quiet noise reading was ~200mA (i think iam reading it correctly, meter was set to 200m level)
-unplugged headlight motor
-meter reads 7.6 (meter still set to 200m level)
-played with manual up down of light fiddled with pulggin it back in
-now sometimes reads ~200 sometimes 7.6
-unplugged headlight motor and left unplugged for good now
-jumped car, wouldnt jump right away had to leave cables connected for a couple minutes before car would start.
-got car started and left running
-gauge in car at charging level reading at alt 14.5v
-let it run til gauge said wasnt charging
-tested at alt and batt meter read 13.7 while car was running
-turn car off
-batt reads 12.5v
-try to immediately restart car
-slow crank for a half second then clicking (4 or 5 clicks before stopeed trying)
-batt now reads 9.9v
am i looking at a starter problem here? defective battery? i am taking the battery back tomorrow to have them check it. in my limited experience i feel as tho the battery just doesnt have the cca in it, am i completely off base? i dont think the headlight motors have anything to do with it since they were unpluged and i still had issues.
i have searched and referenced some info from these threads:
https://www.camaroz28.com/forums/gen...causes-848304/
https://www.camaroz28.com/forums/gen...estion-413346/
Old Feb 13, 2012 | 06:32 PM
moparman's Avatar
Re: starting problem, very slow crank then clicking.
Bad battery would be my guess. I've never had luck with Interstate batteries.
Old Feb 13, 2012 | 07:02 PM
rv93's Avatar
its your battery for sure. get it load tested, then get a new one. the testing is just in case im wrong, lol
Old Feb 15, 2012 | 01:29 AM
and...... it was the battery. when they hooked up their tester while it was on the car as soon as he switched it to test from just showing the voltage there was a spark and then lotss of bad clicks coming from his test machine. replaced the battery with a double checked one and it good to go.
Old Feb 15, 2012 | 12:20 PM
whitdog54's Avatar
always nice when its a simple problem haha
liamcg97
Nov 25, 2019 05:55 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Jessie4tin
Jan 7, 2015 08:53 AM
1LEThumper
Jul 14, 2003 12:45 PM
