Squeek when wheel fully turned?
Old Jul 3, 2004 | 07:04 PM
Slappy3243's Avatar
I have annoying squeek/squeal or something similar when I have the steering wheel fully turned to the point where I am unable to turn it anymore. I can't tell where the squeek is coming from though. At first I though the rear-end my be the culprit, but I heard when that is failing it makes a grinding sound. Perhaps it is just the power steering or the side of the tire? Anybody else have something similar?
Old Jul 3, 2004 | 07:27 PM
Spinner's Avatar
Dumb question, but is it coming from your power steering pump?
Old Jul 3, 2004 | 09:20 PM
Slappy3243's Avatar
I don't think its the pump. That happened on my previous firebird but this sounds different. Thanks for the suggestion though.
Old Jul 3, 2004 | 09:42 PM
n2ceptor's Avatar
Does it make the sound sitting still turning the wheel or when you are moving????
Old Jul 4, 2004 | 07:13 AM
Slappy3243's Avatar
Only makes the sounds when the wheel is fully turned and won't turn anymore and the car is moving.
Old Jul 4, 2004 | 09:53 AM
n2ceptor's Avatar
Might be the front wheel bearing hub assembly.... But, mine just a humming noise at highway speeds going into a gradual turn....
Old Jul 4, 2004 | 04:29 PM
LT1 PWRD's Avatar
I don't know about the rear ends in your car but I had a similar problem in my 95 when the rear diff oil lost all it's viscosity (previous owner never changed it????) and the clutches were squeeling pretty bad.
Old Jul 5, 2004 | 05:05 PM
JoeliusZ28's Avatar
my rear end makes a squeak when turning left and seems to be once per wheel revolution. My oil is fresh too, and was pretty fresh when I changed it, but idk the full history of it. I know the lsd works though
Old May 4, 2006 | 11:50 AM
transAMdriv3r's Avatar
Re: Squeek when wheel fully turned?
mine makes a squeeking sound when i only turn left, and its not constant.
jj71787
Dec 30, 2014 02:15 PM
CaRParts102
Dec 6, 2014 08:45 AM
ro2207
Dec 4, 2014 06:18 PM
formula79
26
Aug 5, 2002 12:21 PM
