Is the speedometer right?
Old Jan 14, 2007 | 12:05 PM
mrmint69's Avatar
If i take the car out and time my 0-60 times is the speedometer accurate enough to do this. Does the gauge take more time to reach 60 then the car does? My old 79 would be reading a slower speed on hard acceleration but as soon as i let off the gas it would still be going and catch up.
Old Jan 14, 2007 | 12:10 PM
razor02097's Avatar
If your just curious then yes but if you are serious then take it to a dyno.
Old Jan 15, 2007 | 08:21 AM
FuryZ28's Avatar
If you buy certain gauges, it will figure that out for you. I replaced my gauges with Nordskog digital gauges, and the speedometer not only has pushbutton calibration, but it has the capability of measuring and displaying your 1/4 mile time & 0-60 time. The only catch is you gotta make sure you get the calibration on the speedo right, or neither of those figures will be accurate...
Old Jan 20, 2007 | 05:51 PM
CALL911's Avatar
G-Tech makes a device that accuratly reads your 0-60 time as well as other things. Otherwise, unless you have strayed your car in wheel/tire size from stock or done anything to change the gearing, your stock speedo should be pretty darn accurate.
Old Jan 21, 2007 | 07:32 PM
Z95m6's Avatar
No i don't think your stock gauges are accurate enough to try to calculate this. When i had my scanmaster in and on the mph setting the speedo would fall behind by up to 5mph on a hard acceleration compared to the scanmaster.
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 12, 2015 10:12 PM
red
Apr 6, 2003 08:02 PM
Michael Ozorowsky
Oct 2, 2002 01:58 PM
