Is the speedometer right?
If i take the car out and time my 0-60 times is the speedometer accurate enough to do this. Does the gauge take more time to reach 60 then the car does? My old 79 would be reading a slower speed on hard acceleration but as soon as i let off the gas it would still be going and catch up.
G-Tech makes a device that accuratly reads your 0-60 time as well as other things. Otherwise, unless you have strayed your car in wheel/tire size from stock or done anything to change the gearing, your stock speedo should be pretty darn accurate.
No i don't think your stock gauges are accurate enough to try to calculate this. When i had my scanmaster in and on the mph setting the speedo would fall behind by up to 5mph on a hard acceleration compared to the scanmaster.
mattstrike
Mar 12, 2015 10:12 PM
