speedo issues
Old Nov 4, 2012 | 04:00 PM
chevyman1217's Avatar
speedo issues
I have a 1994 camaro with a 3.4L and the t-5 5 speed that im having issues with the speedometer. I have been using my GPS for the speedometer because at 80 it says im doing 15 mph the odometer and trip meter both work just slow because the speedometer isnt working correctly.
Any ideas on what to do to fix this issue?
any help would be great
Old Nov 4, 2012 | 07:17 PM
Re: speedo issues
Is it possible someone replaced the PCM with a unit from an automatic trans car, and did not reprogram it to work with the T5 manual?
Have you scanned it for codes to see if there is one for the vehicle speed sensor (VSS)?
Old Nov 4, 2012 | 09:42 PM
Re: speedo issues
i dont have any codes stored or coming up do you think it might be the pcm?
Old Nov 5, 2012 | 11:55 AM
Re: speedo issues
With the V8 engines there is a difference in the number of VSS pulses per output shaft rev. The 4L60E has a 40 tooth reluctor and the T56 has a 17 tooth. I don't know about the V6 and the T5 trans. In the S10 pickups it also used a 40 tooth reluctor.
Do you know if the trans or the PCM has been swapped? Have you had this problem as long as you've owned the car?
Old Nov 6, 2012 | 07:00 PM
Cool Re: speedo issues
im not sure if it has been swapped i have only had the car a couple weeks. I have been wanting one of this body style for a while and this was the cleanest of all the ones I looked at. The only thing that I could find wrong with it was the speedo issue and the gas guage hasn't worked right since I put a new fuel pump in it. It also sounds like a bad bearing in the tranny when you down **** and the rpm's go up. When you take it out of gear or engage the clutch the noise goes away. Not sure what that is either haven't taken the tranny out yet to find out. I'm wanting to switch it to the T56 6 speed but not sure if I can do that and keep the hopped up v-6. do you know anything about doing that kind of swap?
Old Nov 20, 2016 | 01:58 PM
Steven Jackson's Avatar
Re: speedo issues
I'm having trouble with my Speedo sensor as well...I just replaced it but found out that a mousexy chewed through the wires on top of the transmission...does anyone know where the wires run from the Speedo sensor...Ive tried to follow it but I can't findo any diagrams online...I just need to find out where to connect the wires again....
Old Nov 20, 2016 | 03:53 PM
Re: speedo issues
The main engine harness wraps around the back of the engine. A branch drops off and goes down the left (driver) side of the bell housing and trans, to the VSS on the tailshaft. See attached .pdf
The VSS has two wires, one yellow and one purple. The yellow wire attaches to PCM pin B30, the purple to pin B29.
File Type: pdf
jackpawt883
Jun 14, 2015 09:59 AM
blac94Z
Feb 10, 2015 11:02 AM
Jul 4, 2005 05:00 PM
99TransAmWS6
3rd Gen / L98 Engine Tech
Sep 13, 2002 12:10 PM
Chrisdude
Aug 31, 2002 12:08 AM
