Spare tire wont fit on front! help!
Hey guys, this is messed up. My spare tire only fits on the rear. If I try and put it on the front, its like the lug nuts are forcing it over the brake assembly and the car wont move! As for as I know the camaro came with this spare.
If you do that, make sure you don't go over 50 mph. Anything over that and you risk damage to the rear end (this should be printed on the spare, but just a heads up).
Ya I wouldent drive over that speed. I see a lot of idiots on the highway flying with a spare, seen some just after they blew too haha.
The spare wouldent fit on the rear either!! I wonder if it is the right spare, it says 15 on there somewhere but I run 16's.
Does anyone have a pic of there spare to see if mine is the right one?
I got a new tire today so its all good. I had to walk to work, only half hour of walking away haha. My boss said I should shim the tire out a 1/4 or so inches with an aluminum plate. (im a steel fabricator) Might make one if I dont get this spare figured out.
It has the right pattern. I can put the tire onto the lugs but when I tighten down I can hear it squeezing over the brake assembly. I decided for kicks to move the car a couple of inches and it squeeled real bad. Like the rim isnt fitting over the brake calipers
haha, yeah, not trunk at all, you even have to remove the little trunk flap. But I never use my trunk anyway. And Im usually driving far, if I get a flat I'd rather just throw on a tire and drive normally as if nothing had happened.
Hurin
Dec 13, 2014 07:38 PM
squarehead
Nov 21, 2014 08:02 PM
ZPLYR 19
Aug 22, 2002 01:44 PM
