something is really wrong with my car>
Old May 24, 2004 | 02:25 PM
Chrisz24's Avatar
At idel it feels fine, and I can rev it all the way to red line in Neutral.
In drive or under a load the engine doesnt sound right when I push the gas, it hesitates, and bucks, and sounds excessively loopy. I had to floor it just to get up a hill and it felt like it was going to die any minute.
I'm home, today is excessively hot, I had the AC on, but I turned it off when it started to have problems.
I think I might buy a fuel filter since this is the origional one and the car has 36,000 miles.
Any help would be greately appreciated!
~Chris
Old May 24, 2004 | 02:48 PM
Chrisz24's Avatar
I'm going to the auto parts store right now to get a fuel filter.
Cheep/first thing I guess I should check.
Old May 24, 2004 | 09:44 PM
Chrisz24's Avatar
I gave up, I could only reach the fuel filter by lifting the rear wheels really high up, but with a full tank of gas I cant stop the gas while I change the filter.
I need to get my trans fluid changed/ coolent or whatever else so I'm just going to pay somone wed to fix it.
Hopefuly it's back soon, this weather is too nice to be driving a Tahoe
Old May 24, 2004 | 09:55 PM
JaysGone's Avatar
Cant tell you why your ride is crappy. But to change the fuel filter in a 3800 you have to have 1/2 a tank or as little as you feel comfortable with. It will leak some fuel no matter what. I use a golf tee to plug up the line when I change mine.
Old May 26, 2004 | 01:37 AM
Ace_437's Avatar
First of all you shouldn't rev the motor to redline while in neutral. That's a good way to do some damage. About your fuel filter, just back the car up onto some Rhino Ramps and take it off. Yes, some fuel will come out, but it eventually stops. It's not just going to continue to run out unless you've wired your fuel pump to constantly be on!
Old May 26, 2004 | 04:31 PM
Chrisz24's Avatar
It was impossible, I had the rear wheels up on ramps and I had so much gas in the tank that it wouldnt stop coming out.
So I sent the car out to my mechanic to do it, He called me just a little wile ago, aparently my #6 spark plug wire went out I'm confused and suprised since the car has such low miles.
Now I'm wondering if I should do the rest of the wires/plugs just so their all even
Old May 26, 2004 | 04:44 PM
JaysGone's Avatar
Milage has very little to do with wire and other components condition as much as age and heat do. A 98 V-6 you say. 6 years is 3 years to late.Change all 6 spark plug wires at the very least.
Old May 26, 2004 | 04:47 PM
Chrisz24's Avatar
I was'nt going to wate till 100,000 like the manual says, but I was hoping to get to atleast 60-70K
I'll look into changing the rest, first I'd like to just get it back and drive it.
Old May 26, 2004 | 05:05 PM
robb4964's Avatar
Might be the converter .
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
Aaront810
Sep 11, 2015 11:24 AM
