So how many of you bent the fender tabs on the bottom of the car?
I finally did it today - drive over a curb stop. Not bad though - just the edge of the passenger side tab was bent a little. I unbolted the fender and bent it back. Man, did I feel dumb.
Re: So how many of you bent the fender tabs on the bottom of the car?
Not while driving - but did a number on the left side while using a 4 pt lift to raise the car to change the oil though - and I knew better, just wasn't careful.
Mine are bent as well. The fenders stick out like a half inch or something. Cound i put a crecent wrench right on the bolts and bend it back? or does hitting it work the best?
What are the chances of the metal breaking? mine has been bent and put back in place once before (dont ask). Should i use my best judgement?
You should always use your best judgement . But seriously, if it does break, it wouldn't be hard to tack weld it back on.
Some moron that owned the car fore i did decided thatd be a good point to use the jack. I used vice grips on mine enough to get a small grip then gently pryed it back flush. The fenders are plastic so now only one bolt it holding it on as the other cracked. Just be careful and go slow and you shouldnt have a problem.
