Smog tube bent - where to get replacement?
Old May 9, 2020 | 09:35 PM
starfishy's Avatar
As I live in California, deleting the AIR/smog pump is not an option. Visual inspection would immediately find that. I tried replacing the clogged smog check valves, which was pretty easy on the passenger side, but the driver side metal tube between the manifold and the valve on the drivers side was/is stuck on the tube to the manifold. I unbolted the tube and heated the connection and tried to get the valve off, but in the process bent the tube (stupid, I know). I was able to mount it again, but the tube has only about half the opening area next to the screw mount of the valve and the valve is still stuck on the thread. I've tried to find a replacement tube, as the valve still needs to be replaced, but can't find the part anywhere. Does anyone know the part number to look for?
Old May 9, 2020 | 10:18 PM
Re: Smog tube bent - where to get replacement?
Year, model, engine info would be helpful. Given it's CA, trans type is also important for a 95.
Old May 9, 2020 | 10:27 PM
starfishy's Avatar
Oops, I totally spaced out on that.. 2000 Camaro SS M6. Engine is stock.
pikfiredawg
Jun 8, 2008 08:52 AM
kevinsz2895
Jul 29, 2005 06:28 PM
TimChiaretto
Parts Wanted
Oct 1, 2004 08:20 AM
RRios8191
Jun 29, 2003 06:07 PM
SC383
N2O Tech
May 14, 2003 07:52 PM
