small block install
Old Mar 24, 2009 | 04:26 PM
70cuda's Avatar
small block install
So i'm looking to put the 383 stroker into my 94. But after I pulled the v6 I dont think the motor mounts will work, any one have prior knowledge of this engine swap ? I can make some mounts if there are none available. The motor has only 2000 miles on it and came out of my 72 Camaro that was wrecked beyond repair . I'm also looking at a 5 or 6 speed to go behind it . The motor will stay with a carb ( no FI here ) so I can remove the computer and wiring , just going with a simple race car type wiring harness but steet legal with all the lights working. Cant wait to get my weekend street cruser going .
Old Mar 24, 2009 | 07:14 PM
The V6 models have a completely different K-member than the V8 models. To swap an LT1 into a V6 you have to swap K-members. Is your SBC an LT1 or a Gen 1?
If you delete the PCM, you will delete the speedometer function.
Old Mar 24, 2009 | 08:01 PM
70cuda's Avatar
motor swap
It's an early 74 block, from a Chevelle, I had for years in the back of the garage . I built it a couple of years ago for the Camaro, but thats gone now. Will the v6 crossmember hold up the v8 if I make custom mounts? Or I can get one from the junk yard. As far the speedo I'm going to put in after market gages. A roll cage will be going this summer as well as a suspension lowering kit.
Old Mar 24, 2009 | 09:16 PM
JooneJune's Avatar
70 cuda, you may be in some serious luck. I'm done with my V6-V8 swap. and I am taking the V8 out to go into my firebird. which leaves a ton of parts you would need. I have everything from the harnesses, to the K member, suspension, gauges, PCM,... pm me if your interested.
Old Mar 26, 2009 | 08:22 AM
teke184's Avatar
could go with an aftermarket K member from a place like BMR. save some weight.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
kennyirocz
3rd Gen / L98 Engine Tech
Feb 7, 2015 11:41 PM
89 iroc zl1
Jan 14, 2015 02:18 AM
Collector Car
Jan 5, 2015 10:58 AM
