A slightly different clogged cat question
Old Nov 29, 2006 | 02:15 PM
Red95M6Z28's Avatar
Question A slightly different clogged cat question
If your cat is clogged will it let the car operate properly while its cold, then cause power loss after its warm?
My car runs 100% until it gets up to tempature.....then it cuts out quickly, stumbling and sputtering, and I have about 1/2 mile to get somewhere till it dies completely and wont restart!
After you let it sit for 30 minutes it will restart, but die again quickly.
Old Nov 29, 2006 | 02:27 PM
OBE1 95Z28's Avatar
A clogged cat will be problematic warm or cold as It is restricting the exhaust gas. Sounds like you could have a O2 sensor problem as the car's air/fuel mixture changes when the engine warms up to the point that the O2 sensors are used by the PCM to set AFR.
Old Nov 29, 2006 | 02:47 PM
Red95M6Z28's Avatar
Whats funny is it had a SES light on for the 02 sensor. So I bought the sensor and took it to the shop, but it had an exahust leak right by the o2 sensor. So the welded up the leak and it made the light go off.
However, the "problem" I have developed the SAME DAY I took it from the shop.
alex5366
Feb 17, 2015 09:07 AM
David Dorris
Jan 17, 2015 08:10 PM
cmdeshon
Dec 27, 2014 10:06 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Dec 1, 2014 08:08 AM
