Siemens vs Dorman Window Motor
Old Aug 5, 2008 | 02:32 AM
SiNfulSS's Avatar
Autozone lists two different companys, which one is the preferred one to go with these days? Siemens or Dorman?
Old Aug 5, 2008 | 03:27 AM
Green96Z's Avatar
The cheapest one. Make sure it has a lifetime warranty. All the motors are pretty much the same anyway.
On another note, the Autozone website shows the Cardone motor has a $15 core return, so you can ask them about that.
Old Aug 5, 2008 | 03:55 AM
SiNfulSS's Avatar
Yeah that's cause the Cardone is a REMAN. Where's it looks like the Siemens and Dorman are possibly new.
Old Aug 5, 2008 | 07:05 AM
Green96Z's Avatar
Reman. is the same as new. It's just the old case with new guts. Like I said, they will all last about the same. They all have the same defect, so it doesn't really matter anyway.
Old Aug 6, 2008 | 02:07 AM
SiNfulSS's Avatar
Yeah I figured as much but I could swear that I saw somewhere at one point where someone was saying that the Siemens ones are all redesigned or something...
Old Aug 6, 2008 | 07:45 AM
blackbirdta's Avatar
i don't know which brand, but the one i got from advance auto blew out in 5 weeks. i just replaced it again yesterday. i guess it's good i had the lifetime warrenty. i have now replaced 3 window motors in 2 months
Old Aug 6, 2008 | 10:26 AM
Green96Z's Avatar
If you keep blowing out motors then you have other problems. Check for an obstruction on the tracks, and grease the rails and rollers.
Old Aug 6, 2008 | 10:31 AM
Wild Willy's Avatar
And measure the voltage to the motor- if you run them at too low volts, they go slow, get hot, and burn up- They make a relay kit to run like 10 or 12 ga. wire to the motor, and use the switch to fire the relays for the heavy cable-
Go with the cheapest one with a lifetime guarantee-
Old Aug 11, 2008 | 08:10 AM
Chevyssoccer's Avatar
I went through 3 motors on pass and 2 on drivers, and both started going so slow (a good 30 seconds bottom to top). So I made my own relay kit for both doors with 8 gauge off the battery with the same motors and now they are faster than in my 2006 Tundra
Old Aug 15, 2008 | 12:08 PM
DeuceGI's Avatar
The Dorman looks just like the the NAPA motor I installed about a month ago--both have a cast aluminum gear head and both are mfg in Vietnam. The NAPA motor works but is NOISY as hell. I ended up across the street at Advance where they had the Siemens motor in stock (stamped steel housing--made in USA) for the same price. I'll know after the weekend if its as quiet as OEM. HTH
Keenan
Jan 19, 2023 12:24 PM
onefastgta
Mar 19, 2015 10:09 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
