Shift points...HP or TQ??...lshift ight setting...
Old Sep 2, 2006 | 10:12 PM
Bayer-Z28's Avatar
Do you shift for TQ or HP drop off?
I'm looking at my dyno sheet... (all rw #'s)
@2400rpm (where pull is marked from/starts) my hp is at about 145... my TQ is at about 315
My hp levels off at 5300rpm, and drops at a little over 5700rpm.
My tq is level from 4000rpm thru 5000 rpm. drops off at 5000 and really starts to fall at 5500rpm.
What should I set a shift light to? I would think Hp drop off because TQ is almost immediately available. Where as the HP climbs for about another 500rpm.
Thanx..
Old Sep 3, 2006 | 08:23 AM
teke184's Avatar
Re: Shift points...HP or TQ??...lshift ight setting...
set the light at 6K....so you're shifting before the limiter
wish i had a copy of the test that showed the 1/4mi times from using the various "shift point" theories.
on shifted at peak torque, one peak hp and one at near redline....redline was the fastest
Old Sep 3, 2006 | 11:26 AM
Bayer-Z28's Avatar
^oh, Ok... Trying to land back in the 'powerband'.. I guess.. I'm gettign a NOS dry kit soon. If I had the window switch kill the nitrous @ 5600 or 5800rpm.... I might just set the light for 6 or 5900..
Old Sep 3, 2006 | 11:46 AM
teke184's Avatar
that sounds about right
and yes....when you shift you want to still be in your power band
Old Sep 3, 2006 | 03:22 PM
Bayer-Z28's Avatar
cool... oh, and my RL was reset to 6500 I think (ls1edit).. won't go there, there's no power there and I fear bent pushrods.
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
